I use the EMMC for the OS and application code and I'm looking to add extra storage for samples, somewhere between 16GB and 128GB. It seems I can use microSD cards and (short/small) USB sticks. The storage device will not be hotplugged/removed but the instrument will likely not gracefully shutdown. The storage device will be used incidentally to read samples, and it seems unlikely the user would remove power while loading samples.
As far as I can tell, the data transfer speed on the Beaglebone side suggests USB (2.0 or higher) might be a bit faster.
USB 2.0 HS: 30-50 MB/s
microSD: 24 MB/s
However, both are flash technology, and will probably have similar actual read and write speeds.
The (auto)mounting USB/SD cards process is the same, and for both technologies it is recommended to umount before removing it (or removing power?).
It seems to me that the only difference between SD cards and USB sticks is that SD cards are cheaper and smaller, and USB sticks possibly faster. Am I missing something?
