dipaloka Hi there Im a beginner to lots of this… I’d like to use one of the speaker amps with a patch built in Pure Data, what ‘dac~ x’ objects should be used to send audio out?
giuliomoro if you have a Bela Cape, any audio output that is sent to the headphone out is also automatically sent to the speaker outputs, however in order for the speaker output to be enabled you need to provide 5V to the board via the barrel jack, see here
