Good morning!
I’ve been delayed in installing the new image mostly because I had a lot of concerts, and I didn’t want to risk a full re-patching process, especially with the TrillCraft UGens, WiFi setup, and all the wiring on my instrument.
Now, though, I’ve finally tried the new image on a fresh micro USB card, but I’m running into issues using SuperCollider with the audio input channels. I always rely on the SoundIn UGen to capture the signals from my pickups—currently, I’m working with 9 inputs: 8 electromagnetic pickups (very low gain) plus one Arduino mic input (which is louder). When I run my simple code to listen to all these channels, I only get sound from channel 0 and 1. Even after modifying the server options (setting the input bus channels to 10 and output bus channels to 10), it still doesn’t work. I checked other patches, and they run fine, so it seems isolated to this one SuperCollider patch.
Do you have any idea what might have changed in the new image or if there’s something I missed in the configuration? Any advice would be super appreciated. Thanks so much!
Best,
Rafaele
