Recently, I faced a problem. I used UDP and usb cable to send the bela data to my windows computer through matlab, but I found some data are loss. So I want to use ethernet to replace usb. I know if using ethernet, the first step is changing the ip from DHCP to static ip. I've changed /etc/network/interfaces, the relevant content of the file is shown below:
auto etho0
iface eth0 inet static
address 192.168.1.10
netmask 255.255.255.0
gateway 192.168.1.1
Then resarting it, however, the ethernet doesn't work. So anyone can tell me how to use ethernet to send the data? Thank you!
