Hi
I got my BELA out again after a long time. Finished building the pepper Ver.2 and it all worked well. When trying out (for the first time) a Trill sensor it wouldnt work. Problem was a bad solder pin on the I2C connecion. once I got that redone I put everything back together and now I get this error with all programs I try to run.
Building project ...
make: Nothing to be done for 'all'.
Build finished
Running project ...
gpio/direction: No such file or directory
Segmentation fault
make: *** [runide] Error 139
Bela stopped
root@bela ~/Bela#
This happens with the new Pepper shield but also when I take it off and just run the Bela Cape. I tried with the old Pepper Ver 1 shield, with the same problem. I cant spot any damage to the Bela cape (no bend pins..) Software is all up to date
Any idea what to look for going by the Error message I get?
Any help would be much appriciated.
Thanks
Wolfgang
