markh Hello, is anyone here aware of a ready-made cable for the amplified outputs of full-fat Bela? Searching variations on "2-pin female molex to [xlr, jack] cable" hasn't yielded anything that I wouldn't have to build
giuliomoro I think the closest to that you can find are the cables that comes with Bela; they have 3.5mm jacks and if you plug them so that the black and white cables mate with the two pins on the power amp, then you'll get the speaker's signal on the sleeve and tip of the 3.5mm socket. Note that these speaker outputs are push-pull so none of the signals from the two channels should be shorted to each other or to ground.
markh Ah I did wonder if something like this was the quickest solution but wasn't certain. Thanks as always : )
