Hello,
I want to use my bela board as uart receiver following this tuto:
https://learn.bela.io/using-bela/advanced-topics/bela-as-a-uart-adapter/#picking-a-uart-port
https://github.com/BelaPlatform/Bela/wiki/Load-a-device-tree-overlay
Here's my uenv.txt
"uenvcmd=echo loading ${fdtfile}; load mmc ${mmcid}:2 ${fdtaddr} boot/dtbs/${uname_r}/${fdtfile}; if env exists uboot_overlay_addr0; then setenv overlay ${uboot_overlay_addr0}; run bela_loadoverlay; fi; if env exists uboot_overlay_addr1; then setenv overlay ${uboot_overlay_addr1}; run bela_loadoverlay; fi; if env exists uboot_overlay_addr2; then setenv overlay ${uboot_overlay_addr2}; run bela_loadoverlay; fi; if env exists uboot_overlay_addr3; then setenv overlay ${uboot_overlay_addr3}; run bela_loadoverlay; fi; if env exists uboot_overlay_addr4; then setenv overlay ${uboot_overlay_addr4}; run bela_loadoverlay; fi; if env exists uboot_overlay_addr5; then setenv overlay ${uboot_overlay_addr5}; run bela_loadoverlay; fi; if env exists uboot_overlay_addr6; then setenv overlay ${uboot_overlay_addr6}; run bela_loadoverlay; fi; if env exists uboot_overlay_addr7; then setenv overlay ${uboot_overlay_addr7}; run bela_loadoverlay; fi; load mmc ${mmcid}:2 ${loadaddr} /boot/vmlinuz-${uname_r}; setenv bootargs console=${console} root=/dev/mmcblk${mmcid}p2 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet; bootz ${loadaddr} - ${fdtaddr};
bela_loadoverlay=echo loading ${overlay}; load mmc ${mmcid}:2 ${rdaddr} ${overlay}; fdt addr $fdtaddr; fdt resize 0x60000; fdt apply ${rdaddr}; fdt resize 0x60000;
uboot_overlay_addr2=/lib/firmware/BB-BELA-00A1.dtbo
uboot_overlay_addr3=/lib/firmware/BB-BELA-CTAG-SPI-00A0.dtbo
uboot_overlay_addr4=/lib/firmware/BB-UART4-00A0.dtbo
console=ttyS0,115200n8
uname_r=4.14.108-ti-xenomai-r143
mmcid=1
Once I type the command:
root@bela ~/Bela# config-pin p9.11 uart
I have the following:
P9_11 pinmux file not found!
Pin has no cape: P9_11
I have tried to add another line following the comment:
" On Bela, you have to load the /lib/firmware/cape-universala-00A0.dtbo overlay (using one of the techniques above) first in order for config-pin to work. "
uboot_overlay_addr5= /lib/firmware/cape-universala-00A0.dtbo
But then the Bela board boot and shutdown after 10 secs. FYI I am running v0.3.8g
Could you let me know how to be able to set inputs as uart?
Thanks
Romain
