D300 Hey, I tried this and I´m getting in the console
Did you run that command on your host computer? If yes, then try ssh root@192.168.7.2, that will probably tell you you have a stale entry in ~/.ssh/known_hosts that needs to be cleared before this can work.
D300 i assumed the internal git manager of the BELA IDE creates a repository on my git account, b
What do you mean by "git account"?
D300 In the end it would be nice to have a workflow which enables commiting code from the bela IDE git manager from one board. pulling it down on another board etc. . can this workflow work with the current git manager?
Sort of. The easiest way is if the boards could all access the same git repo, either because they are all connected to the internet, or because such repo is hosted on a local computer that they have ssh access to. In that case, once one board's repo has been updated with the latest modifications, that board should push to the centralised repo and all the others should pull from it. How many boards do you have and how are they connected ?
