• Forum
  • Bela booting/connecting from emmc
Hi, I have a Bela kit that will boot from the updated and flashed sd card running 0.3.8f image. It connects to the IDE fine. I can ssh into it at 192.168.7.2.
- I followed the tutorial to flash the emmc.
- I have also run the following command from the sd booted IDE
root@bela ~/Bela# /opt/Bela/bela_bootloader.sh && echo success
emmc contains Bela image
fatfs_boot
success
/root/Bela
However, when I reboot, remove the SD card and try to boot from the emmc image, the board leds flash and then the left most one blinks like it is booted. But it does not connect in my network preferences. I have a macbook pro 2020 running Big Sur 11.6.
Thanks!
it may be that the flashing didn't go well. I'd suggest you boot again from the SD card and run:
/opt/Bela/bela_flash_emmc.sh
and only that (don't run the flash_bootloader one). Ensure it doesn't print any error message and try again booting without SD card.
Thanks for responding! I have tried that a few times. Here is the output from the IDE terminal
root@bela ~/Bela# /opt/Bela/bela_flash_emmc.sh
+ '[' -z '' ']'
+ FLASH_DESTINATION=emmc
+ '[' emmc == emmc ']'
+ DEVICE=/dev/mmcblk1
+ MMCID=1
+ THIS_DEVICE=/dev/mmcblk0
++ mktemp -d /tmp/emmc_boot.XXXXXX
+ MNT_BOOT=/tmp/emmc_boot.ptQfNu
++ mktemp -d /tmp/emmc_root.XXXXXX
+ MNT_ROOT=/tmp/emmc_root.0fPCDV
++ mktemp -d /tmp/boot.XXXXX
+ MNT_THIS_BOOT=/tmp/boot.B9KhP
+ USR1=/sys/class/leds/beaglebone:green:usr1/trigger
+ USR2=/sys/class/leds/beaglebone:green:usr2/trigger
+ USR3=/sys/class/leds/beaglebone:green:usr3/trigger
+ SUCCESS=0
+ trap final_check EXIT
+ make --no-print-directory -C /root/Bela stop
No process to kill
+ echo default-on
+ echo default-on
+ echo default-on
+ grep /dev/mmcblk1p2
+ mount
+ grep -q 'on / '
+ umount -A /dev/mmcblk1p1
umount:
/dev/mmcblk1p1: not mounted
+ true
+ umount -A /dev/mmcblk1p2
umount:
/dev/mmcblk1p2: not mounted
+ true
+ grep /dev/mmcblk1
+ mount
+ sfdisk /dev/mmcblk1
+ echo '
label: dos
label-id: 0x68a0906e
device: /dev/mmcblk1
unit: sectors
/dev/mmcblk1p1 : start= 2048, size= 137953, type=c, bootable
/dev/mmcblk1p2 : start= 141312, type=83
Checking that no-one is using this disk right now ... OK
Disk /dev/mmcblk1: 3.6 GiB, 3825205248 bytes, 7471104 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x68a0906e
Old situation:
Device Boot Start End Sectors Size Id Type
/dev/mmcblk1p1 * 2048 140000 137953 67.4M c W95 FAT32 (LBA)
/dev/mmcblk1p2 141312 7471103 7329792 3.5G 83 Linux
>>> Script header accepted.
>>> Created a new DOS disklabel with disk identifier 0x68a0906e.
/dev/mmcblk1p1: Created a new partition 1 of type 'W95 FAT32 (LBA)' and of size 67.4 MiB.
Partition #1 contains a vfat signature.
Partition #2 contains a ext4 signature.
/dev/mmcblk1p2: Created a new partition 2 of type 'Linux' and of size 3.5 GiB.
+ mkfs.vfat /dev/mmcblk1p1
/dev/mmcblk1p3: Done.
New situation:
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
mkfs.fat 4.1 (2017-01-24)
+ mkfs.ext4 -F /dev/mmcblk1p2
mke2fs 1.43.4 (31-Jan-2017)
Discarding device blocks:
4096/916224
528384/916224
done
Creating filesystem with 916224 4k blocks and 229376 inodes
Filesystem UUID: a0ce3976-52fc-4b97-8871-a480b44d9efb
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736
Allocating group tables: 0/28 done
Writing inode tables: 0/28 done
Creating journal (16384 blocks):
done
Writing superblocks and filesystem accounting information: 0/28
done
+ dosfslabel /dev/mmcblk1p1 BELABOOT
+ e2label /dev/mmcblk1p2 BELAROOTFS
+ mount /dev/mmcblk1p1 /tmp/emmc_boot.ptQfNu
+ mount /dev/mmcblk1p2 /tmp/emmc_root.0fPCDV
+ echo 'copying files, this may take a few minutes...'
+ mount /dev/mmcblk0p1 /tmp/boot.B9KhP
+ cp /tmp/boot.B9KhP/MLO /tmp/emmc_boot.ptQfNu
+ sync
+ cp /tmp/boot.B9KhP/u-boot.img /tmp/emmc_boot.ptQfNu
+ sync
+ rsync -r '--exclude=/tmp/boot.B9KhP/MLO,/tmp/boot.B9KhP/u-boot.img,/tmp/boot.B9KhP/FSCK*REC' /tmp/boot.B9KhP/MLO /tmp/boot.B9KhP/bela.version /tmp/boot.B9KhP/drivers /tmp/boot.B9KhP/u-boot.img /tmp/boot.B9KhP/uEnv.txt /tmp/emmc_boot.ptQfNu
+ cat /tmp/boot.B9KhP/uEnv.txt
+ sed 's/^\(\s*mmcid=\).*/\11/'
+ umount /tmp/boot.B9KhP
+ rm -rf /tmp/boot.B9KhP
+ cp -a /bin/ /boot/ /dev/ /etc/ /home/ /lib/ /opt/ /root/ /sbin/ /srv/ /usr/ /var/ /tmp/emmc_root.0fPCDV
yup the last command takes about 10 minutes to execute. While it's running, the lights on the BBB should all be on. When(if) they go back to normal, the process is finished.
Ahhh drp. Thank you!
