HI! I hope you can help, and that it's ok for me to ask for help here. I got a Bela Salt recently, really excited to write some Rust for it. Unfortunately neither bela.local or any of the IP addresses work for it. I've dug around in the forums and code and haven't found an answer.
My situation: I connect via USB to my Mac running Monterey 12.1. The blue LEDS on the board flash and look fine to me. The front panel LEDs, the left one flashes on at startup, but then nothing more happens, which, since this is a used Salt, I can't say if that is just what the previously-installed custom patch does, or if it indicates an error. I assume this is fine because I do get the BELABOOT volume to pop up. Looking at my System Preferences Network tab I see a device in the left column named Bela, status is "Not connected". I've tried a few different USB setups, none of them change anything. The MACOS Drivers available on BELABOOT are (of course) too old for my OS, but from my understanding that shouldn't be needed anyway.
Here is the output of `ifconfig':
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
ether f0:18:98:f0:12:28
inet6 fe80::80:97c3:dc3a:b1e3%en0 prefixlen 64 secured scopeid 0x4
inet 192.168.193.141 netmask 0xffffff00 broadcast 192.168.193.255
media: autoselect (1000baseT <full-duplex,flow-control>)
status: active
en6: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether ac:de:48:00:11:22
inet6 fe80::aede:48ff:fe00:1122%en6 prefixlen 64 scopeid 0x5
status: active
ap1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether a6:83:e7:91:ad:1c
media: autoselect
status: inactive
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=6463<RXCSUM,TXCSUM,TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
ether a4:83:e7:91:ad:1c
inet6 fe80::493:a8d0:4987:1f64%en1 prefixlen 64 secured scopeid 0x7
inet 192.168.193.2 netmask 0xffffff00 broadcast 192.168.193.255
media: autoselect
status: active
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 6a:13:69:ba:fb:f9
inet6 fe80::6813:69ff:feba:fbf9%awdl0 prefixlen 64 scopeid 0x8
media: autoselect
status: active
inet6 fe80::6813:69ff:feba:fbf9%llw0 prefixlen 64 scopeid 0x9
media: autoselect
status: active
en4: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:54:e3:02:98:05
status: inactive
en5: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:54:e3:02:98:04
status: inactive
ether 82:54:e3:02:98:01
status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:54:e3:02:98:00
status: inactive
en8: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=6467<RXCSUM,TXCSUM,VLAN_MTU,TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
ether 48:65:ee:12:eb:b4
media: autoselect (none)
status: inactive
Configuration:
ipfilter disabled flags 0x0
ifmaxaddr 0 port 12 priority 0 path cost 0
member: en3 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 13 priority 0 path cost 0
member: en4 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 10 priority 0 path cost 0
member: en5 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 11 priority 0 path cost 0
media: <unknown type>
status: inactive
inet6 fe80::232d:6072:9eca:20f2%utun0 prefixlen 64 scopeid 0x10
inet6 fe80::3c44:bf68:a373:5316%utun1 prefixlen 64 scopeid 0x11
inet6 fe80::ce81:b1c:bd2c:69e%utun2 prefixlen 64 scopeid 0x12
en7: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether be:1a:84:c5:38:9c
status: inactive
Any guidance, tips, obvious mistakes, or requests for info welcome. Really excited to get this working, just wish I had discovered Bela years ago.
Thanks!
Robert
