I think the best option for you is to recover the cable you cut. These are unshielded wires, so you can easily solder the two ends back together.
If you desperately need a new Molex-type connector, then here you will find more info on the part number (you'll need matching crimp terminals).
Otherwise, drop us a line at info@bela.io .
