The factoring out of x->getTime()
looks good.
There are some errors in the file, it won't build as is. Among others, you are forward-declaring __wrap_time()
but then using __wrap_clock_gettime()
rph-r I confess I'm not sure I understood everything I did with xenomai, but I'll dig that...
__wrap_SOMEFUNCTION()
calls the Xenomai version of SOMEFUNCTION (if available). The forward declaration (extern someret __wrap_SOMEFUNCTION(someargs)
) is a lazy workaround so that you don't need to find the correct file to include and add it to the include path or modify the #include
statements).
Now the issue we encountered is that Xenomai's time()
or clock_gettime(CLOCK_REALTIME, ...)
gives unexpected results (it probably reports the time since boot?). This is probably a bug in Xenomai (or a feature, but I can't find it docuemented) and propagates to the use of time()
- which also uses CLOCK_REALTIME
under the hood. By trial and error I figured out that CLOCK_HOST_REALTIME
yields correct results. However, time()
doesn't support specifying the clock, so we have to use clock_gettime(CLOCK_HOST_REALTIME, ...)
instead, and extract the seconds from the value it returns. As CLOCK_HOST_REALTIME
is defined in the Xenomai include, we once more work around it by hardcoding its value 32
Now that things work, if you wanted to tidy things up in a way that your external can be built on any platform but picks up Xenomai includes and functions if available, you could do the following:
- add this line to the Makefile before including the pdlibbuilder makefile:
CPPFLAGS=-I/usr/xenomai/include/cobalt -I/usr/xenomai/include
This will tell it to look for the Xenomai includes and it will pick up time.h
from there, declaring __wrap_clock_gettime() and defining CLOCK_HOST_REALTIME
- then in the C file you can do simply:
#ifdef CLOCK_HOST_REALTIME
// Xenomai clock, if available
__wrap_clock_gettime(CLOCK_HOST_REALTIME , &tp);
#else
clock_gettime(CLOCK_REALTIME , &tp);
#endif
This is a bit nicer and doesn't require much platform detection: on most systems, /usr/xenomai/
won't exist and so the include paths you set in CPPFLAGS
will be ignored. Note: in principle a change like this would also require to add a library to the list of shared libraries to link the external against. However, we rely on the host (the Bela core in this case) to load that library for us. That's not as neat, but it allows to keep things simple in the Makefile
Further refactoring could see using a class_addanything
instead of individual methods for the various year, month, day etc, but as that's so poorly documented (i.e.: undocumented) in Pd I don't blame you.
It would probably look something like:
void ahora_anything(t_ahora *x, t_symbol* s, int argc, t_atom* argv)
x->get_time(x);
if(s == gensym("year"))
outlet_float(x->year_out , 1900+x->instant.tm_year) ;
else if(s == gensym("month"))
outlet_float(x->month_out , 1+x->instant.tm_mon) ;
else if ...
else
pd_error(x, "no method for %s\n", s->s_name);
// in ahora_setup(), instead of all the individual ahora_addmethod() calls:
class_addanything(ahora_class, (t_anymethod)ahora_anything);
Not sure if's worth anyone's time, but it would look nicer -- if it works. I hope the bang
method still works, otherwise you need to add it as a case in the chain of ifs in ahora_anything()
Btw, you may also want to make the creation argument a symbol instead of a float and convert that to a number internally before storing it into x->whichout
, that would make it more user-friendly.
