What's the best PSU to use with the Bela starter kit? I want run speakers from it. So far I can find 0.5, 1 and 2A
0.5A is enough for running the BeagleBone and Bela cape. To stay safe, when using the speakers you should probably get at least 1.5A. Note also the polarity and size of the barrel jack connector:
it needs to be 5.5mm x 2.1mm with the negative voltage outside and the positive voltage inside (“tip positive” or "center positive").
https://learn.bela.io/using-bela/bela-techniques/powering-bela/
