Hi guys!
I just get started with a BELA Mini and I am having an issue with running my Csound instrument as well as the examples. Below is the error appeared at the end of the console:
1 errors in performance
Elapsed time at end of performance: real: 0.107s, CPU: 0.011s
Makefile:596: recipe for target 'runide' failed
make: *** [runide] Error 1
Bela stopped
I tried my own .csd file, the print example under Fundamental, the Trill examples, and some other examples but the error just happened to them. While a few examples run perfectly fine from time to time, most of them have the same error. I am not sure if there is something wrong with my installation since the example codes should not have any problems.
I would really appreciate it if anyone could help me out! Thank you so much for the patience and support 🙂
