anna @giuliomoro, Is there a good method for galvanically isolating Trill sensors connected to the same Bela? I see that it is possible to buy an I2C isolator (e.g. https://dk.rs-online.com/web/p/kommunikation-og-tradlos-udvikling/1683021), but I am not clear on how this would be connected to the Bela/Trills? Any advice is greatly appreciated! Best, Anna
giuliomoro That should work. The datasheet contains an example application. You'd have Trill instead of the ADM1075 and Bela instead of the microcontroller there. What's the purpose of this application?
anna giuliomoro Thanks for your input here. The goal is to ensure that EEG participants synchronously moving their fingers on separate Trills connected to the same Bela are not electrically coupled. So I would like to find a way to ensure galvanic isolation between the Trills..
