so i'm trying to upgrade my Principium Keyboard to use an OLED.
since i have it running as is (and it's going to be on show end of the week), i thought i'd move everything to a new Bela, see if i can get that up and running, keeping the original untouched until i have everything working.
i upgraded to the latest expermental /dev branch (as needed for I2C oled communication.)
that seems to have worked, at least the IDE's showing up in the browser..
i downloaded all the projects (externals, main project) from the original Bela, and migrated that .zip file to the new one using the method described here:
https://forum.bela.io/d/1295-restore-projects-folder-after-upgrade
i tried running the project, but i get these errors:
Error: unable to initialise audio codec
Makefile:601: recipe for target 'runide' failed
make: *** [runide] Error 1
Bela stopped
root@bela ~/Bela#
i guess i could go back and go through the whole process of installing needed externals again, and setting everything up for automounting the SD card etc, but i was hoping to avoid that..
any thoughts?
i'm on a Seeed BeagleBone Green, by the way, don't know if that is giving me problems..
edit: i get the same errors when running the Basic sketch.
