Hi there,
I have one of the early Belas that says it's "Bela release image, v0.3.0, 1 November 2017"
The unit has no SD card.
I've tried updating it twice via command line, following the instructions on Wiki. Both times the update_board script said the update was successful. However, when I reboot, it again says v0.3.0
Apart from wanting to have the latest update, I want to update because I can't access the board via USB... I need to have LAN cable connected and then I can access via the IP address assigned to the LAN port.
However, I want to use Bela with my Mac, which doesn't have LAN port, only WiFi...
How can I update my Bela and make it work with IDE through USB cable only?
Thanks!
