Hi,
I recently purchased a CTAG BEAST Starter Kit. it has the two capes mounted by default, and I can sucessfully build and run my project using the IDE. However at the moment I do not need the additional in-/outputs and i would like to run a project without the two capes mounted.
However when I unmount the two capes and try to build&run my project i get the following prompt:
Unrecognized Bela hardware: is a cape connected?
Error: unable to initialise audio
make: *** [runide] Error 1
I tried to flash the SD card using Balena Etcher, which worked flawlessly. However, the Error message still appears. So i assume the config for the capes is not stored on the SD card but rather the Bela board itself.
Is there an easy way how i can switch the configs between using the two capes / BEAST and using the Bela board without the capes?
