hi there,
i need to make some modifications to one of my bela instruments.
so i plugged it into my macbook air (with bigsur on it) and i cannot seem to connect over ssh or the IDE (anymore).
connecting via the screen command works just fine.
problem is, i need to download and later re-upload new puredata and heavy files to the board.
the board is on version 0.3.5b
ifconfig shows:
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
options=400<CHANNEL_IO>
ether e0:ac:cb:67:24:d6
inet6 fe80::c45:d694:a375:b344%en0 prefixlen 64 secured scopeid 0x4
inet 192.168.43.184 netmask 0xffffff00 broadcast 192.168.43.255
media: autoselect
status: active
ether 82:18:0a:e4:95:80
inet 192.168.6.1 netmask 0xffffff00 broadcast 192.168.6.255
status: inactive
Configuration:
ipfilter disabled flags 0x0
ifmaxaddr 0 port 5 priority 0 path cost 0
media: <unknown type>
status: inactive
ether 02:ac:cb:67:24:d6
media: autoselect
status: inactive
ether 72:a6:e8:38:cb:8e
inet6 fe80::70a6:e8ff:fe38:cb8e%awdl0 prefixlen 64 scopeid 0x8
media: autoselect
status: active
inet6 fe80::70a6:e8ff:fe38:cb8e%llw0 prefixlen 64 scopeid 0x9
media: autoselect
status: active
inet6 fe80::17fd:208e:662d:cbea%utun0 prefixlen 64 scopeid 0xa
inet6 fe80::9be1:5171:bf3e:66f%utun1 prefixlen 64 scopeid 0xb
en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether be:1a:e3:ba:c0:99
inet6 fe80::4a:8ff9:564d:1179%en5 prefixlen 64 optimistic secured scopeid 0xc
media: autoselect (none)
status: inactive
and /etc/network/interfaces on the board contains the following:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# USB RNDIS gadget (Windows / Linux compatible)
auto usb0
#iface usb0 inet dhcp
iface usb0 inet static
address 192.168.6.2
netmask 255.255.255.0
network 192.168.6.0
# USB ECM gadget (macOS / Linux compatible)
auto usb1
#iface usb1 inet dhcp
iface usb1 inet static
address 192.168.7.2
network 192.168.7.0
is there a workaround to download my files to my macbook? i am willing to update the system later on, if that makes things easier, but would still need to connect first.
