can you create a new C++ project and put this code in there?
unsigned int kNumCh = 7;
// Set the mode of digital pins
for(unsigned int c = 0; c < kNumCh; ++c)
pinMode(context, 0, c, INPUT);
pinMode(context, 0, c + kNumCh, OUTPUT);
for(unsigned int n = 0; n < context->digitalFrames; ++n)
static unsigned int count = 0;
bool val = digitalRead(context, n, c);
if(10000 == count)
rt_printf("%1d ", val);
digitalWriteOnce(context, n, c + kNumCh, val);
if(10000 == count)
rt_printf("\n");
count = 0;
count++;
this should print the values of the first 6 digital inputs (D0 to D6) and echo each of them to out n + 7, e.g.: D0 in -> D7 out, D1 in -> D8 out etc , which in my understanding is what your patch was trying to do. This should help you figure out whether there is a wiring issue or a Pd issue.
