There is a isolated part in my pd patch that causes the error below. But it doesn't occur when I run the isolated part as a separated patch. The patch contains 4 tabread4~ objects, 4 tables, a phasor and some multiplications and a part where the tables are initialised. Do you guys have any suggestions?
Running /root/Bela/projects/heavytest8/heavytest8 -p 128
Starting Heavy context with 23 input channels and 2 output channels
Channels in use:
Digital in : 13, Digital out: 0
Scope out: 0
MIDI device hw:1,0,0 is not ready: No such file or directory
Segmentation fault
make: *** [run] Error 139
