Hello! I have a device a built that is a wireless controller with some sensors. I use the Xbee to communicate with my computer, either with Max or Pure Data, both of which work fine. I'm using the comport object in pure data to read from the usb port, which has an Xbee attached to it. In another thread, it's stated that the comport object won't work well with the bela (if I'm mistaken about this, I'd be thrilled). Is there a way that I can get serial data into a pure data patch through the USB port on salt? The wireless device mounts to my classical guitar and has to be moved around a lot, so connecting the teensy that is within it straight to the salt is not ideal. . . Thanks!
