I still think there's something wrong with it, I've ordered another board to compare against as I'll need a spare for when this thing goes in to installation.
Running that command didn't give anything so I ssh'd in and ran dmesg and got the below
[ 0.000000] Linux version 4.14.108-ti-xenomai-r135 (giulio@builder) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #1xross PREEMPT Fri Jun 5 08:00:21 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c13d4ac8, node_mem_map dfb79000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x3c8 with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
[ 0.000000] Memory: 498272K/524288K available (12288K kernel code, 962K rwdata, 3608K rodata, 1024K init, 843K bss, 26016K reserved, 0K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0d00000 (13280 kB)
.init : 0xc1200000 - 0xc1300000 (1024 kB)
.data : 0xc1300000 - 0xc13f0af4 ( 963 kB)
.bss : 0xc13f2000 - 0xc14c4e54 ( 844 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000018] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000038] I-pipe, 24.000 MHz clocksource, wrap in 178956 ms
[ 0.000057] clocksource: ipipe_tsc: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000079] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000087] OMAP clocksource: timer1 at 24000000 Hz
[ 0.001629] timer_probe: no matching timers found
[ 0.001996] Interrupt pipeline (release #7)
[ 0.002325] Console: colour dummy device 80x30
[ 0.002377] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.022065] pid_max: default: 32768 minimum: 301
[ 0.022271] Security Framework initialized
[ 0.022286] Yama: becoming mindful.
[ 0.022330] AppArmor: AppArmor disabled by boot time parameter
[ 0.022401] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.022415] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.023427] CPU: Testing write buffer coherency: ok
[ 0.023496] CPU0: Spectre v2: using BPIALL workaround
[ 0.024472] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.024684] Hierarchical SRCU implementation.
[ 0.029134] devtmpfs: initialized
[ 0.048624] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.049086] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.049108] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.049465] xor: automatically using best checksumming function neon
[ 0.049478] pinctrl core: initialized pinctrl subsystem
[ 0.051575] NET: Registered protocol family 16
[ 0.053194] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.097926] omap_hwmod: debugss: _wait_target_disable failed
[ 0.147353] OMAP GPIO hardware version 0.1
[ 0.163466] No ATAGs?
[ 0.163487] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.175241] raid6: using algorithm neonx8 gen() 0 MB/s
[ 0.175255] raid6: .... xor() 0 MB/s, rmw enabled
[ 0.175264] raid6: using neon recovery algorithm
[ 0.184323] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.190234] SCSI subsystem initialized
[ 0.190547] usbcore: registered new interface driver usbfs
[ 0.190610] usbcore: registered new interface driver hub
[ 0.190779] usbcore: registered new device driver usb
[ 0.191481] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.191547] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.191594] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.191805] pps_core: LinuxPPS API ver. 1 registered
[ 0.191813] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.191837] PTP clock support registered
[ 0.192749] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.193512] Advanced Linux Sound Architecture Driver Initialized.
[ 0.194317] NetLabel: Initializing
[ 0.194330] NetLabel: domain hash size = 128
[ 0.194337] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.194441] NetLabel: unlabeled traffic allowed by default
[ 0.195048] clocksource: Switched to clocksource ipipe_tsc
[ 0.360429] VFS: Disk quotas dquot_6.6.0
[ 0.360536] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.374034] NET: Registered protocol family 2
[ 0.374933] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.374978] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.375018] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.375287] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.375306] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.375558] NET: Registered protocol family 1
[ 0.376315] RPC: Registered named UNIX socket transport module.
[ 0.376326] RPC: Registered udp transport module.
[ 0.376333] RPC: Registered tcp transport module.
[ 0.376339] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.377300] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.377433] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.379323] audit: initializing netlink subsys (disabled)
[ 0.380449] [Xenomai] scheduling class idle registered.
[ 0.380459] [Xenomai] scheduling class rt registered.
[ 0.380601] I-pipe: head domain Xenomai registered.
[ 0.382085] audit: type=2000 audit(0.380:1): state=initialized audit_enabled=0 res=1
[ 0.388300] [Xenomai] Cobalt v3.0.10 [DEBUG]
[ 0.388471] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.395880] zbud: loaded
[ 0.398990] NFS: Registering the id_resolver key type
[ 0.399317] Key type id_resolver registered
[ 0.399327] Key type id_legacy registered
[ 0.399355] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.399724] fuse init (API version 7.26)
[ 0.400368] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 0.411016] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.411469] io scheduler noop registered
[ 0.411480] io scheduler deadline registered
[ 0.411893] io scheduler cfq registered (default)
[ 0.411904] io scheduler mq-deadline registered
[ 0.411912] io scheduler kyber registered
[ 0.413764] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.414724] ------------[ cut here ]------------
[ 0.414762] WARNING: CPU: 0 PID: 1 at kernel/irq/chip.c:57 irq_set_chip+0xcc/0xdc
[ 0.414770] irqchip 44e07000.gpio is not pipeline-safe!
[ 0.414778] Modules linked in:
[ 0.414798] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.108-ti-xenomai-r135 #1xross
[ 0.414805] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 0.414811] I-pipe domain: Linux
[ 0.414853] [<c0110644>] (unwind_backtrace) from [<c010dc04>] (show_stack+0x20/0x24)
[ 0.414869] [<c010dc04>] (show_stack) from [<c0c44188>] (dump_stack+0x24/0x28)
[ 0.414885] [<c0c44188>] (dump_stack) from [<c013a578>] (warn+0xf4/0x10c)
[ 0.414898] [<c013a578>] (warn) from [<c013a5e8>] (warn_slowpath_fmt+0x58/0x74)
[ 0.414913] [<c013a5e8>] (warn_slowpath_fmt) from [<c01968a4>] (irq_set_chip+0xcc/0xdc)
[ 0.414931] [<c01968a4>] (irq_set_chip) from [<c0197bc0>] (irq_set_chip_and_handler_name+0x24/0x3c)
[ 0.414955] [<c0197bc0>] (irq_set_chip_and_handler_name) from [<c080fb0c>] (gpiochip_irq_map+0x50/0xc8)
[ 0.414972] [<c080fb0c>] (gpiochip_irq_map) from [<c019a6cc>] (irq_domain_associate+0x84/0x1f8)
[ 0.414986] [<c019a6cc>] (irq_domain_associate) from [<c019b0ac>] (irq_create_mapping+0x144/0x1fc)
[ 0.414999] [<c019b0ac>] (irq_create_mapping) from [<c080fbac>] (gpiochip_to_irq+0x28/0x58)
[ 0.415013] [<c080fbac>] (gpiochip_to_irq) from [<c080ef38>] (gpiod_to_irq+0x58/0x70)
[ 0.415062] [<c080ef38>] (gpiod_to_irq) from [<c0815c14>] (gpio_is_visible+0x8c/0xac)
[ 0.415087] [<c0815c14>] (gpio_is_visible) from [<c0393d64>] (internal_create_group+0xdc/0x30c)
[ 0.415104] [<c0393d64>] (internal_create_group) from [<c03943f4>] (sysfs_create_groups+0x54/0x90)
[ 0.415129] [<c03943f4>] (sysfs_create_groups) from [<c08cc75c>] (device_add+0x4d0/0x618)
[ 0.415146] [<c08cc75c>] (device_add) from [<c08cca74>] (device_create_groups_vargs+0xc4/0xd0)
[ 0.415161] [<c08cca74>] (device_create_groups_vargs) from [<c08ccb60>] (device_create_with_groups+0x44/0x60)
[ 0.415175] [<c08ccb60>] (device_create_with_groups) from [<c0816588>] (gpiod_export+0x178/0x398)
[ 0.415189] [<c0816588>] (gpiod_export) from [<c0814df8>] (gpio_request_one+0x114/0x12c)
[ 0.415204] [<c0814df8>] (gpio_request_one) from [<c080e830>] (devm_gpio_request_one+0x58/0x90)
[ 0.415219] [<c080e830>] (devm_gpio_request_one) from [<c0816f44>] (gpio_of_helper_probe+0x19c/0x64c)
[ 0.415238] [<c0816f44>] (gpio_of_helper_probe) from [<c08d22b4>] (platform_drv_probe+0x60/0xbc)
[ 0.415252] [<c08d22b4>] (platform_drv_probe) from [<c08cfd30>] (driver_probe_device+0x298/0x478)
[ 0.415265] [<c08cfd30>] (driver_probe_device) from [<c08d0020>] (driver_attach+0x110/0x12c)
[ 0.415279] [<c08d0020>] (driver_attach) from [<c08cd764>] (bus_for_each_dev+0x70/0xd0)
[ 0.415293] [<c08cd764>] (bus_for_each_dev) from [<c08cf4cc>] (driver_attach+0x2c/0x30)
[ 0.415306] [<c08cf4cc>] (driver_attach) from [<c08cee48>] (bus_add_driver+0x1d0/0x274)
[ 0.415319] [<c08cee48>] (bus_add_driver) from [<c08d0de8>] (driver_register+0x88/0x104)
[ 0.415332] [<c08d0de8>] (driver_register) from [<c08d21fc>] (platform_driver_register+0x50/0x58)
[ 0.415357] [<c08d21fc>] (platform_driver_register) from [<c12451cc>] (gpio_of_helper_driver_init+0x20/0x28)
[ 0.415375] [<c12451cc>] (gpio_of_helper_driver_init) from [<c0101d78>] (do_one_initcall+0x64/0x19c)
[ 0.415395] [<c0101d78>] (do_one_initcall) from [<c1200f9c>] (kernel_init_freeable+0x154/0x1f4)
[ 0.415413] [<c1200f9c>] (kernel_init_freeable) from [<c0c58ee0>] (kernel_init+0x18/0x11c)
[ 0.415434] [<c0c58ee0>] (kernel_init) from [<c0109478>] (ret_from_fork+0x18/0x24)
[ 0.415453] ---[ end trace f431cb120861f706 ]---
[ 0.416466] gpio-of-helper ocp:cape-universal: ready
[ 0.419819] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 0.421290] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.424765] console [ttyS0] disabled
[ 0.424864] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 38, base_baud = 3000000) is a 8250
[ 0.436670] console [ttyS0] enabled
[ 0.439769] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 0.522876] libphy: Fixed MDIO Bus: probed
[ 0.579111] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 0.579128] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 0.579737] MDIO: davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 0.581637] libphy: 4a101000.mdio: probed
[ 0.581670] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 0.582692] cpsw 4a100000.ethernet: Detected MACID = 00:35:ff:91:b5:eb
[ 0.582819] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 0.582830] cpsw 4a100000.ethernet: ALE Table size 1024
[ 0.582882] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 0.587398] mmc1: new high speed MMC card at address 0001
[ 0.590778] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.590827] ehci-platform: EHCI generic platform driver
[ 0.591451] mmcblk1: mmc1:0001 M62704 3.53 GiB
[ 0.591934] ehci-omap: OMAP-EHCI Host Controller driver
[ 0.592764] usbcore: registered new interface driver usb-storage
[ 0.594355] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 0.594745] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 0.596602] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.597008] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB
[ 0.598640] mmcblk1: p1 p2
[ 0.604650] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 0.609022] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.609064] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.609429] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.609441] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.609450] usb usb1: Product: MUSB HDRC host driver
[ 0.609459] usb usb1: Manufacturer: Linux 4.14.108-ti-xenomai-r135 musb-hcd
[ 0.609467] usb usb1: SerialNumber: musb-hdrc.1
[ 0.610367] hub 1-0:1.0: USB hub found
[ 0.610444] hub 1-0:1.0: 1 port detected
[ 0.619655] mousedev: PS/2 mouse device common for all mice
[ 0.622245] omap_rtc 44e3e000.rtc: registered as rtc0
[ 0.623340] i2c /dev entries driver
[ 0.625066] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.628337] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.629090] ashmem: initialized
[ 0.629529] remoteproc remoteproc0: wkup_m3 is available
[ 0.636307] NET: Registered protocol family 10
[ 0.637853] Segment Routing with IPv6
[ 0.637934] mip6: Mobile IPv6
[ 0.637954] NET: Registered protocol family 17
[ 0.638077] Key type dns_resolver registered
[ 0.638086] mpls_gso: MPLS GSO support
[ 0.638348] omap_voltage_late_init: Voltage driver support not added
[ 0.645310] PM: Cannot get wkup_m3_ipc handle
[ 0.649968] ThumbEE CPU extension supported.
[ 0.650985] registered taskstats version 1
[ 0.651224] zswap: loaded using pool lzo/zbud
[ 0.653755] Btrfs loaded, crc32c=crc32c-generic
[ 0.655193] Key type encrypted registered
[ 0.691214] random: fast init done
[ 0.701335] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 0.701919] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.702432] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.702509] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.704219] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 400 kHz
[ 0.706022] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.706414] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.706781] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.707308] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.707379] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz
[ 0.709147] remoteproc remoteproc0: powering up wkup_m3
[ 0.709278] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[ 0.712724] PM: Cannot get wkup_m3_ipc handle
[ 0.717462] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 0.717481] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[ 0.718290] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 0.718306] of_cfs_init
[ 0.718441] of_cfs_init: OK
[ 0.719444] ALSA device list:
[ 0.719455] No soundcards found.
[ 0.722522] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
[ 0.722536] EXT4-fs (mmcblk1p2): write access will be enabled during recovery
[ 0.814974] EXT4-fs (mmcblk1p2): recovery complete
[ 0.816378] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.816488] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 0.817575] devtmpfs: mounted
[ 0.819141] Freeing unused kernel memory: 1024K
[ 1.087807] systemd[1]: System time before build time, advancing clock.
[ 1.136153] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.165788] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.169374] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.182239] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 1.183297] systemd[1]: Detected architecture arm.
[ 1.184549] systemd[1]: Set hostname to <bela>.
[ 1.393704] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 1.794976] systemd[1]: Listening on Syslog Socket.
[ 1.798279] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.798562] systemd[1]: Reached target Swap.
[ 1.799733] systemd[1]: Listening on Journal Audit Socket.
[ 1.800150] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 1.800387] systemd[1]: Reached target Remote File Systems.
[ 1.802134] systemd[1]: Created slice User and Session Slice.
[ 1.913762] rtdm_pruss_irq: loading out-of-tree module taints kernel.
[ 1.914557] rtdm_pruss_irq version 2 loaded
[ 1.990453] usbcore: registered new interface driver snd-usb-audio
[ 2.050573] PM: bootloader does not support rtc-only!
[ 2.575420] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 3.129775] systemd-journald[104]: Received request to flush runtime journal from PID 1
[ 5.777804] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 7.770298] using random self ethernet address
[ 7.770319] using random host ethernet address
[ 7.833812] using random self ethernet address
[ 7.833832] using random host ethernet address
[ 7.911351] Mass Storage Function, version: 2009/09/11
[ 7.911377] LUN: removable file: (no medium)
[ 9.251323] usb0: HOST MAC be:1a:ff:91:b5:ec
[ 9.251874] usb0: MAC be:1a:ff:91:b5:ed
[ 9.257353] usb1: HOST MAC be:1a:ff:91:b5:ef
[ 9.257724] usb1: MAC be:1a:ff:91:b5:f0
[ 9.848802] net eth0: initializing cpsw version 1.12 (0)
[ 9.929117] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 9.942013] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.203422] configfs-gadget gadget: high-speed config #1: c
[ 10.788197] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 11.295320] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[ 13.879258] random: crng init done
[ 13.879283] random: 7 urandom warning(s) missed due to ratelimiting
[ 1921.601747] rtdm_pruss_irq_open
[ 6159.950510] configfs-gadget gadget: high-speed config #1: c
