hi there, i try to compile a "huge" project on bela-mini. up until now i compiled on bela and copied the binary over.
the project has lv2host, heavy (pd things) combined in a big render. the compilation works but i get this on linking:
root@bela:~/Bela/projects# make -C ~/Bela PROJECT=livevox3 COMPILER=gcc run
make: Entering directory '/root/Bela'
No process to kill
Building symap.c...
...done
Building HvSignalSample.c...
...done
Building lilv_interface.c...
...done
Building Heavy_bela.cpp...
In file included from /root/Bela/projects/livevox3/Heavy_bela.hpp:44:0,
from /root/Bela/projects/livevox3/Heavy_bela.cpp:33:
/root/Bela/projects/livevox3/HvSignalTabread.h: In function 'void __hv_tabread_stoppable_f(SignalTabread*, float32x4_t*)':
/root/Bela/projects/livevox3/HvSignalTabread.h:134:15: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (o->head == ~0x0) {
In file included from /root/Bela/projects/livevox3/Heavy_bela.hpp:46:0,
/root/Bela/projects/livevox3/HvSignalTabwrite.h: In function 'void __hv_tabwrite_stoppable_f(SignalTabwrite*, float32x4_t)':
/root/Bela/projects/livevox3/HvSignalTabwrite.h:77:15: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (o->head != HV_TABWRITE_STOPPED) {
...done
Building render.cpp...
...done
Building Lv2Host.cpp...
/root/Bela/projects/livevox3/Lv2Host.cpp: In member function 'bool Lv2Host::disconnect(unsigned int, unsigned int)':
/root/Bela/projects/livevox3/Lv2Host.cpp:168:9: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if(-1 == destinationSlotNumber) {
/root/Bela/projects/livevox3/Lv2Host.cpp: In member function 'void Lv2Host::render(unsigned int, const float**, float**)':
/root/Bela/projects/livevox3/Lv2Host.cpp:199:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if(slots.size() == slot)// pass-through, handled below
...done
Building HvHeavy.cpp...
/root/Bela/projects/livevox3/HvHeavy.cpp:24:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
#pragma mark - Heavy Table
/root/Bela/projects/livevox3/HvHeavy.cpp:45:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
#pragma mark - Heavy Message
/root/Bela/projects/livevox3/HvHeavy.cpp:127:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
#pragma mark - Heavy Common
/root/Bela/projects/livevox3/HvHeavy.cpp:294:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
...done
Extracting dependencies of library Gui
Extracting dependencies of library sndfile
Linking...
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `fatal.constprop.3':
lilv_interface.c:(.text+0x40): undefined reference to `lilv_instance_free'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_cleanup':
lilv_interface.c:(.text+0x7a): undefined reference to `lilv_instance_free'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_instantiatePlugin':
lilv_interface.c:(.text+0xd6): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0xe4): undefined reference to `lilv_world_get_all_plugins'
lilv_interface.c:(.text+0xea): undefined reference to `lilv_plugins_get_by_uri'
lilv_interface.c:(.text+0xf2): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x104): undefined reference to `lilv_plugin_get_num_ports'
lilv_interface.c:(.text+0x13c): undefined reference to `lilv_plugin_get_port_ranges_float'
lilv_interface.c:(.text+0x148): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x154): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x160): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x16c): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x178): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x1a6): undefined reference to `lilv_port_is_a'
lilv_interface.c:(.text+0x1c6): undefined reference to `lilv_plugin_get_port_by_index'
lilv_interface.c:(.text+0x1f0): undefined reference to `lilv_port_has_property'
lilv_interface.c:(.text+0x1fc): undefined reference to `lilv_port_is_a'
lilv_interface.c:(.text+0x20a): undefined reference to `lilv_port_is_a'
lilv_interface.c:(.text+0x22e): undefined reference to `lilv_port_is_a'
lilv_interface.c:(.text+0x23c): undefined reference to `lilv_port_is_a'
lilv_interface.c:(.text+0x260): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x266): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x26c): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x272): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x278): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x288): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x292): undefined reference to `lilv_plugin_has_feature'
lilv_interface.c:(.text+0x29e): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x2b0): undefined reference to `lilv_port_get_index'
lilv_interface.c:(.text+0x2d0): undefined reference to `lilv_new_string'
lilv_interface.c:(.text+0x2da): undefined reference to `lilv_plugin_get_port_by_symbol'
lilv_interface.c:(.text+0x2e2): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x346): undefined reference to `lilv_plugin_instantiate'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_initializeWorld':
lilv_interface.c:(.text+0x426): undefined reference to `lilv_world_new'
lilv_interface.c:(.text+0x432): undefined reference to `lilv_world_load_all'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_printPorts':
lilv_interface.c:(.text+0x470): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x488): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x496): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x4a4): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x4b2): undefined reference to `lilv_new_uri'
/root/Bela/projects/livevox3/build/lilv_interface.o:lilv_interface.c:(.text+0x4c0): more undefined references to `lilv_new_uri' follow
lilv_interface.c:(.text+0x4e4): undefined reference to `lilv_plugin_get_uri'
lilv_interface.c:(.text+0x4e8): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x4fa): undefined reference to `lilv_plugin_get_name'
lilv_interface.c:(.text+0x502): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0x514): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x51a): undefined reference to `lilv_plugin_get_class'
lilv_interface.c:(.text+0x51e): undefined reference to `lilv_plugin_class_get_label'
lilv_interface.c:(.text+0x524): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0x536): undefined reference to `lilv_plugin_get_author_name'
lilv_interface.c:(.text+0x53e): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0x550): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x556): undefined reference to `lilv_plugin_get_author_email'
lilv_interface.c:(.text+0x55e): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x570): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x576): undefined reference to `lilv_plugin_get_author_homepage'
lilv_interface.c:(.text+0x57e): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x590): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x596): undefined reference to `lilv_plugin_has_latency'
lilv_interface.c:(.text+0x5a2): undefined reference to `lilv_plugin_get_latency_port_index'
lilv_interface.c:(.text+0x5b4): undefined reference to `lilv_plugin_get_bundle_uri'
lilv_interface.c:(.text+0x5b8): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x5ca): undefined reference to `lilv_plugin_get_library_uri'
lilv_interface.c:(.text+0x5d2): undefined reference to `lilv_plugin_get_library_uri'
lilv_interface.c:(.text+0x5d6): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x5e8): undefined reference to `lilv_plugin_get_uis'
lilv_interface.c:(.text+0x5ee): undefined reference to `lilv_nodes_size'
lilv_interface.c:(.text+0x5fa): undefined reference to `lilv_uis_free'
lilv_interface.c:(.text+0x60a): undefined reference to `lilv_plugin_get_data_uris'
lilv_interface.c:(.text+0x610): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0x61a): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x630): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0x634): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x644): undefined reference to `lilv_nodes_next'
lilv_interface.c:(.text+0x64e): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x664): undefined reference to `lilv_plugin_get_required_features'
lilv_interface.c:(.text+0x67c): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0x686): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x69c): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0x6a0): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x6b0): undefined reference to `lilv_nodes_next'
lilv_interface.c:(.text+0x6ba): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x6d2): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0x6d8): undefined reference to `lilv_plugin_get_optional_features'
lilv_interface.c:(.text+0x6f0): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0x6fa): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x710): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0x714): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x724): undefined reference to `lilv_nodes_next'
lilv_interface.c:(.text+0x72e): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x746): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0x74c): undefined reference to `lilv_plugin_get_extension_data'
lilv_interface.c:(.text+0x764): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0x76e): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x784): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0x788): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x798): undefined reference to `lilv_nodes_next'
lilv_interface.c:(.text+0x7a2): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x7ba): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0x7c8): undefined reference to `lilv_plugin_get_related'
lilv_interface.c:(.text+0x7e0): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0x800): undefined reference to `lilv_nodes_get_first'
lilv_interface.c:(.text+0x804): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0x812): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0x81a): undefined reference to `lilv_nodes_next'
lilv_interface.c:(.text+0x824): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x830): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0x83a): undefined reference to `lilv_world_load_resource'
lilv_interface.c:(.text+0x846): undefined reference to `lilv_world_find_nodes'
lilv_interface.c:(.text+0x860): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0x864): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0x87a): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0x880): undefined reference to `lilv_plugin_get_num_ports'
lilv_interface.c:(.text+0x8b0): undefined reference to `lilv_plugin_get_port_ranges_float'
lilv_interface.c:(.text+0x8ee): undefined reference to `lilv_plugin_get_port_by_index'
lilv_interface.c:(.text+0x906): undefined reference to `lilv_port_get_classes'
lilv_interface.c:(.text+0x914): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0x91e): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x928): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0x938): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0x946): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0x956): undefined reference to `lilv_nodes_next'
lilv_interface.c:(.text+0x960): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0x976): undefined reference to `lilv_port_is_a'
lilv_interface.c:(.text+0x984): undefined reference to `lilv_port_get_scale_points'
lilv_interface.c:(.text+0x99c): undefined reference to `lilv_scale_points_begin'
lilv_interface.c:(.text+0x9a8): undefined reference to `lilv_scale_points_get'
lilv_interface.c:(.text+0x9ae): undefined reference to `lilv_scale_point_get_value'
lilv_interface.c:(.text+0x9b2): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0x9ba): undefined reference to `lilv_scale_point_get_label'
lilv_interface.c:(.text+0x9be): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0x9d0): undefined reference to `lilv_scale_points_next'
lilv_interface.c:(.text+0x9da): undefined reference to `lilv_scale_points_is_end'
lilv_interface.c:(.text+0x9e6): undefined reference to `lilv_scale_points_free'
lilv_interface.c:(.text+0x9ee): undefined reference to `lilv_port_get_symbol'
lilv_interface.c:(.text+0x9f2): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0xa06): undefined reference to `lilv_port_get_name'
lilv_interface.c:(.text+0xa0c): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0xa1e): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0xa2e): undefined reference to `lilv_port_get_value'
lilv_interface.c:(.text+0xa34): undefined reference to `lilv_nodes_size'
lilv_interface.c:(.text+0xa40): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0xa4e): undefined reference to `lilv_port_get_value'
lilv_interface.c:(.text+0xa54): undefined reference to `lilv_nodes_size'
lilv_interface.c:(.text+0xa60): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0xa6e): undefined reference to `lilv_port_is_a'
lilv_interface.c:(.text+0xa7a): undefined reference to `lilv_port_get_properties'
lilv_interface.c:(.text+0xa80): undefined reference to `lilv_nodes_size'
lilv_interface.c:(.text+0xa8a): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0xa94): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0xaa0): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0xaa4): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0xab0): undefined reference to `lilv_nodes_next'
lilv_interface.c:(.text+0xaba): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0xaca): undefined reference to `lilv_nodes_size'
lilv_interface.c:(.text+0xad4): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0xb10): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0xb16): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0xb1c): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0xb22): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0xb28): undefined reference to `lilv_node_free'
/root/Bela/projects/livevox3/build/lilv_interface.o:lilv_interface.c:(.text+0xb2e): more undefined references to `lilv_node_free' follow
lilv_interface.c:(.text+0xb9c): undefined reference to `lilv_nodes_get_first'
lilv_interface.c:(.text+0xba0): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0xbb2): undefined reference to `lilv_nodes_get_first'
lilv_interface.c:(.text+0xbb6): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0xbcc): undefined reference to `lilv_port_get_value'
lilv_interface.c:(.text+0xbd2): undefined reference to `lilv_nodes_size'
lilv_interface.c:(.text+0xbda): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0xbf6): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0xc02): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0xc06): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0xc16): undefined reference to `lilv_nodes_next'
lilv_interface.c:(.text+0xc20): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0xc36): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0xc40): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0xc4c): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0xc52): undefined reference to `lilv_plugin_get_optional_features'
lilv_interface.c:(.text+0xc5e): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0xc68): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0xc74): undefined reference to `lilv_nodes_free'
lilv_interface.c:(.text+0xc7a): undefined reference to `lilv_plugin_get_extension_data'
lilv_interface.c:(.text+0xc86): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0xc90): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0xca8): undefined reference to `lilv_uis_begin'
lilv_interface.c:(.text+0xcc0): undefined reference to `lilv_uis_is_end'
lilv_interface.c:(.text+0xccc): undefined reference to `lilv_uis_get'
lilv_interface.c:(.text+0xcd2): undefined reference to `lilv_ui_get_uri'
lilv_interface.c:(.text+0xcd6): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0xce4): undefined reference to `lilv_ui_get_binary_uri'
lilv_interface.c:(.text+0xce8): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0xcf0): undefined reference to `lilv_ui_get_classes'
lilv_interface.c:(.text+0xcf6): undefined reference to `lilv_nodes_begin'
lilv_interface.c:(.text+0xd00): undefined reference to `lilv_nodes_get'
lilv_interface.c:(.text+0xd04): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0xd14): undefined reference to `lilv_nodes_next'
lilv_interface.c:(.text+0xd1e): undefined reference to `lilv_nodes_is_end'
lilv_interface.c:(.text+0xd3a): undefined reference to `lilv_ui_get_bundle_uri'
lilv_interface.c:(.text+0xd3e): undefined reference to `lilv_node_as_uri'
lilv_interface.c:(.text+0xd50): undefined reference to `lilv_uis_next'
lilv_interface.c:(.text+0xd5a): undefined reference to `lilv_uis_is_end'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_connectPorts':
lilv_interface.c:(.text+0xf58): undefined reference to `lilv_plugin_get_num_ports'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_getPortRanges':
lilv_interface.c:(.text+0x100c): undefined reference to `lilv_plugin_get_num_ports'
lilv_interface.c:(.text+0x1040): undefined reference to `lilv_plugin_get_port_ranges_float'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_getPortName':
lilv_interface.c:(.text+0x107a): undefined reference to `lilv_plugin_get_port_by_index'
lilv_interface.c:(.text+0x1084): undefined reference to `lilv_port_get_name'
lilv_interface.c:(.text+0x108a): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0x1092): undefined reference to `lilv_node_free'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_getControlPortType':
lilv_interface.c:(.text+0x10b0): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x10bc): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x10c8): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x10d4): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x10e0): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x10ee): undefined reference to `lilv_plugin_get_port_by_index'
lilv_interface.c:(.text+0x10fc): undefined reference to `lilv_port_is_a'
lilv_interface.c:(.text+0x1110): undefined reference to `lilv_port_is_a'
lilv_interface.c:(.text+0x111e): undefined reference to `lilv_port_has_property'
lilv_interface.c:(.text+0x1128): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x112e): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x1134): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x113a): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x1140): undefined reference to `lilv_node_free'
lilv_interface.c:(.text+0x1150): undefined reference to `lilv_port_has_property'
lilv_interface.c:(.text+0x1160): undefined reference to `lilv_port_has_property'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_getPortIndex':
lilv_interface.c:(.text+0x118e): undefined reference to `lilv_new_string'
lilv_interface.c:(.text+0x1198): undefined reference to `lilv_plugin_get_port_by_symbol'
lilv_interface.c:(.text+0x11a0): undefined reference to `lilv_port_get_index'
lilv_interface.c:(.text+0x11a8): undefined reference to `lilv_node_free'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_isLogarithmic':
lilv_interface.c:(.text+0x11be): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x11ca): undefined reference to `lilv_plugin_get_port_by_index'
lilv_interface.c:(.text+0x11d4): undefined reference to `lilv_port_has_property'
lilv_interface.c:(.text+0x11dc): undefined reference to `lilv_node_free'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_hasStrictBounds':
lilv_interface.c:(.text+0x11f6): undefined reference to `lilv_new_uri'
lilv_interface.c:(.text+0x1202): undefined reference to `lilv_plugin_get_port_by_index'
lilv_interface.c:(.text+0x120c): undefined reference to `lilv_port_has_property'
lilv_interface.c:(.text+0x1214): undefined reference to `lilv_node_free'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_getPluginName':
lilv_interface.c:(.text+0x1224): undefined reference to `lilv_plugin_get_name'
lilv_interface.c:(.text+0x122a): undefined reference to `lilv_node_as_string'
lilv_interface.c:(.text+0x1232): undefined reference to `lilv_node_free'
/root/Bela/projects/livevox3/build/lilv_interface.o: In function `LV2Apply_cleanupWorld':
lilv_interface.c:(.text+0x90): undefined reference to `lilv_world_free'
lilv_interface.c:(.text+0xb40): undefined reference to `lilv_node_free'
Makefile.linkbela:42: recipe for target '/root/Bela/projects/livevox3/livevox3' failed
make[1]: *** [/root/Bela/projects/livevox3/livevox3] Error 1
Makefile:543: recipe for target '/root/Bela/projects/livevox3/livevox3' failed
make: *** [/root/Bela/projects/livevox3/livevox3] Error 2
do i miss some dependencies? i am a bit lost...
