Thank you for your prompt reply! 🙂
lol
that is your own IP on that network, so you are just pinging yourself!
lol
jan_musi@Jans-MacBook-Pro ~ % ifconfig
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
options=400<CHANNEL_IO>
ether f4:5c:89:ca:96:af
inet6 fe80::4ae:18ea:2983:55a0%en0 prefixlen 64 secured scopeid 0x4
inet 192.168.0.103 netmask 0xffffff00 broadcast 192.168.0.255
media: autoselect
status: active
ether 82:17:08:48:54:00
status: inactive
ether 82:17:08:48:54:01
status: inactive
Configuration:
ipfilter disabled flags 0x0
ifmaxaddr 0 port 5 priority 0 path cost 0
ifmaxaddr 0 port 6 priority 0 path cost 0
media: <unknown type>
status: inactive
ether 06:5c:89:ca:96:af
media: autoselect
status: inactive
ether 5e:0e:c3:42:9f:cc
inet6 fe80::5c0e:c3ff:fe42:9fcc%awdl0 prefixlen 64 scopeid 0x9
media: autoselect
status: active
inet6 fe80::5c0e:c3ff:fe42:9fcc%llw0 prefixlen 64 scopeid 0xa
media: autoselect
status: active
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::2757:caac:c5bc:f3fb%utun2 prefixlen 64 scopeid 0xd
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::17de:9b4b:88d2:1b82%utun3 prefixlen 64 scopeid 0xe
utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::f8a0:8259:5610:8ca7%utun4 prefixlen 64 scopeid 0xf
utun5: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::c47d:6fce:e528:5837%utun5 prefixlen 64 scopeid 0x10
inet6 fe80::8fb:cb5a:7c78:6a25%utun0 prefixlen 64 scopeid 0x11
inet6 fe80::2c3c:6b5b:44a:b718%utun1 prefixlen 64 scopeid 0x12
en4: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether be:1a:d9:3f:8e:31
inet6 fe80::821:48b7:aa29:d063%en4 prefixlen 64 secured scopeid 0x14
inet 169.254.138.217 netmask 0xffff0000 broadcast 169.254.255.255
status: active
bridge100: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=3<RXCSUM,TXCSUM>
ether f6:5c:89:ac:c6:64
inet 192.168.2.1 netmask 0xffffff00 broadcast 192.168.2.255
inet6 fe80::1ce5:cab0:5e8:60c3%bridge100 prefixlen 64 secured scopeid 0x15
Configuration:
member: en4 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 20 priority 0 path cost 0
media: autoselect
status: active
jan_musi@Jans-MacBook-Pro ~ % ls /dev/tty.usb*
/dev/tty.usbmodem__bela__6
jan_musi@Jans-MacBook-Pro ~ % ls /Volumes
BELABOOT Macintosh HD
