Hello,
Yesterday I picked up a Bela mini which I have not used in a year. I updated the software through the IDE
and I when I tried to run an example project from the IDE I came across with the following errors.
Building project ...
make: Nothing to be done for 'all'.
Build finished
Running project ...
PRU interrupt timeout, -1 110 Connection timed out
McASP error, abort
make: *** [runide] Error 1
Bela stopped
I am getting the same error with any C++ example, PD example or SC example.
The Bela did not have anything plugged in apart from the usb cable.
I went through the forum trying to look for similar problems and I could not get a solution that worked for me, for example: rebooting bela, plugging out and in the usb cable, and this bela mini is soldered the right way around.
I run an example project from the terminal and below is the output. I also added the i2cdetect command, as in the other forum answers it seemed to be useful for debugging.
Thanks for your time,
root@bela:~/Bela/scripts# ./build_project.sh ../examples/Fundamentals/print/
Checking the board is up and running at root@192.168.7.2...Warning: Permanently added '192.168.7.2' (ECDSA) to the list of known hosts.
done
Board found at root@192.168.7.2
Stop running process...
Copying new source files to the board...using rsync...
render.cpp
Building and running project...
Building render.cpp...
...done
Linking...
...done
Running /root/Bela/projects/print/print
This Bela example has just started running!
Here's the value of pi: 3.141593
McASP error, abort
Makefile:586: recipe for target 'runonly' failed
make: *** [runonly] Error 1
root@bela:~/Bela/scripts# i2cdetect -y -r 2
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- 18 -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@bela:~/Bela/scripts# i2cdetect -y -r 1
