Ok, so is there a way to turn the Bela into a FX loop? I want to feed my guitar signal into the Bela. I also want to have 2 effects PCB circuits into a FX Loop of the Bela so I can use the (2)Trill pads to individually trigger each effect.
The reason I say put in loop, is that most of these touch pads I have run across require I2C interface to communicate so I can't just throw it into the guitar PCB circuit like a switch. Is that correct?
And to make things even more complicate I want to use the Bela with a 3rd trill sensor to make an XY Kaos pad effect, that will also alter the Guitar signal. Then sending that guitar signal out to the guitar amp
Is that possible because I am clueless on coding
Cheers
