I have run out of vertical space inside my enclosure and can't mount the multiplexer atop Bela. The most convenient place in my setup is to solder it to the strip board my pots are mounted on.
The pinout for the multiplexer suggests that, along with the analog pins, only 7 pins are used from the 46 pin headers p8 & p9. Can anyone confirm whether or not any of the other pins are connected to anything at all? I'm concerned about shorting something out that I haven't noticed. Other than the +5v, ground, 8 analog in and 6 mux pins do I need to consider anything else?
Also, the pinouts on the github schematics don't match the animated pinout. Is this because some pins have multiple potential uses?
