I'm wondering what the pros and cons are of using the line out pins instead of the audio out pins on the bela mini?
As far as I can tell from the chip data sheet and bela schematic, the audio out pins are able to drive higher power loads than the line outs. Is there an advantage to using the line out pin (e.g. noise performance etc) if there is no need to drive headphones etc?
Do the line out pins always mirror the signal on the audio out pins?
