hi,
I'm thinking of using Bella to create an audio station for use in theater and at home. with thrill sliders and knobs.
I was wondering if every channel can have its own separate control and can have its own sound file played to/from it. Or do they all just play the same sound file with it?
That way by using Bluetooth transmitters to each output, one or two Bluetooth boxes can be connected to it.
And then it could be used for ambisonics and stereo. And can you easily connect it to a pc and/or daw like reaper using something called jack?
Is this possible and how would you go about it?
Thank you for having a quick look at it.
