P.S. And here is the course code that I used (with TO DOs filled in). And I should note that I tried several audio cables, and all yielded the same issue. And changing the pulse duration also results in different distortions, again suggesting some sort of filter issue?
____ _____ _ _
| __ )| ____| | / \
| _ \| _| | | / _ \
| |_) | |___| |___ / ___ \
|____/|_____|_____/_/ \_\
http://bela.io
C++ Real-Time Audio Programming with Bela - Lecture 10: Latency
latency-tester-audio: Measures the latency from audio output to audio input
// Constants that define the program behaviour
const unsigned int kTestsPerSecond = 4; // How many tests to run per second
const float kPulseLength = .02; // Length of the output pulse
const float kInputLoThreshold = 0.05; // Input thresholds: look for an edge
const float kInputHiThreshold = 0.15; // from below the "lo" to above the "hi"
// Global variables
float gLastInput = 0; // Previous value of the audio input
unsigned int gTestInterval = 0; // Samples between successive tests
unsigned int gPulseLength = 0; // How long is the pulse in samples?
unsigned int gTestCounter = 0; // How many samples since the last test?
bool gInTest = false; // Are we running a test?
bool gInputAboveThreshold = false; // Is the input high or low?
// The Bela oscilloscope
Scope gScope;
// Initialise the number of samples between successive pulses
// and the length of the pulse
gTestInterval = context->audioSampleRate / kTestsPerSecond;
gPulseLength = context->audioSampleRate * kPulseLength;
// Set up the browser-based oscilloscope
gScope.setup(2, context->audioSampleRate);
// Loop through the number of audio frames
float input = 0;
float output = 0;
// Average the audio inputs
for(unsigned int ch = 0; ch < context->audioInChannels; ch++) {
input += fabsf(audioRead(context, n, ch));
input /= (float)context->audioInChannels;
// TODO 1:
// Increment gTestCounter, and when it reaches the interval,
// start a new test by setting gInTest to true
// Don't forget to reset gTestCounter. If gInTest was *already*
// true, it means the last test never finished (i.e. timeout,
// no signal received back)
if(++gTestCounter >= gTestInterval) {
gTestCounter=0;
if(gInTest){
rt_printf("Pulse timeout\n");
gInTest = true;
// If we are counting samples, then look for a rising edge above the threshold
if(gInTest) {
if(!gInputAboveThreshold && input >= kInputHiThreshold) {
// Edge found: stop counting samples
gInTest = false;
gInputAboveThreshold = true;
// TODO 2:
// In this location, gTestCounter holds the total number of elapsed
// samples since the pulse was generated. Calculate the adjusted latency
// by subtracting the amount we would expect from Bela's own buffering
// Calculate adjusted latency by subtracting twice the buffer size
int normalisedSamples = gTestCounter - 2*context->audioFrames;
// Print the calculated latency
rt_printf("Latency: %.2fms (%d samples) --- hardware: %.2fms (%d samples)\n",
1000.0 * gTestCounter / context->audioSampleRate,
gTestCounter,
1000.0 * normalisedSamples / context->audioSampleRate,
normalisedSamples);
// Update the previous input
gLastInput = input;
// Generate the pulse if we are still in its window
if(gTestCounter < gPulseLength) {
output = 1.0 - (float)gTestCounter / (float)gPulseLength;
else {
output = 0.0;
// If the input falls below the lower threshold, set the flag accordingly
if(input < kInputLoThreshold) {
// Write the output to all the channels
for(unsigned int ch = 0; ch < context->audioOutChannels; ch++) {
audioWrite(context, n, ch, output);
// Log the output and response to the scope
gScope.log(output, input);
