Hello,
____ _____ _ _
| __ )| ____| | / \
| _ \| _| | | / _ \
| |_) | |___| |___ / ___ \
|____/|_____|_____/_/ \_\
http://bela.io
C++ Real-Time Audio Programming with Bela - Lecture 4: Parameter control
wavetable-slider: oscillator example using a browser-based GUI for control
#include <libraries/GuiController/GuiController.h>
#include <cmath>
const int gWavetableLength = 512; // The length of the buffer in frames
float gWavetable[gWavetableLength]; // Buffer that holds the wavetable
float gReadPointers[2] = {0, 0}; // Position of the last frame we played
// Browser-based GUI to adjust parameters
Gui gui;
GuiController controller;
// Generate a sawtooth waveform (a ramp from -1 to 1) and
// store it in the buffer. Notice: generating the wavetable does
// not depend on the audio sample rate (why not?)
for(unsigned int n = 0; n < gWavetableLength; n++) {
gWavetable[n] = -1.0 + 2.0 * (float)n / (float)(gWavetableLength - 1);
// Set up the GUI
gui.setup(context->projectName);
controller.setup(&gui, "Wavetable Controller");
// Arguments: name, default value, minimum, maximum, increment
controller.addSlider("Frequency", 220, 55, 440, 0);
controller.addSlider("Amplitude", -20, -40, 0, 0);
controller.addSlider("Detune", 0, 0, 0.05, 0);
float frequency = controller.getSliderValue(0); // Frequency is first slider
float amplitude = controller.getSliderValue(1); // Amplitude is second slider
float detune = controller.getSliderValue(2); // Detune is our third slider
float amplitude = powf(10.0, amplitudeDB / 20); // I RECEIVE AN ERROR HERE
float frequencies[2];
frequencies[0] = centreFrequency * (1.0 + detune); // I RECEIVE AN ERROR HERE
frequencies[1] = centreFrequency * (1.0 - detune); // I RECEIVE AN ERROR HERE, TOO
float out = 0;
for(unsigned int i = 0; i < 2; i++) {
// The pointer will take a fractional index. Look for the sample on
// either side which are indices we can actually read into the buffer.
// If we get to the end of the buffer, wrap around to 0.
int indexBelow = floorf(gReadPointers[i]);
int indexAbove = indexBelow + 1;
if(indexAbove >= gWavetableLength)
indexAbove = 0;
// For linear interpolation, we need to decide how much to weigh each
// sample. The closer the fractional part of the index is to 0, the
// more weight we give to the "below" sample. The closer the fractional
// part is to 1, the more weight we give to the "above" sample.
float fractionAbove = gReadPointers[i] - indexBelow;
float fractionBelow = 1.0 - fractionAbove;
// Calculate the weighted average of the "below" and "above" samples
out += amplitude * (fractionBelow * gWavetable[indexBelow] +
fractionAbove * gWavetable[indexAbove]);
gReadPointers[i] += gWavetableLength * frequencies[i] / context->audioSampleRate;
while(gReadPointers[i] >= gWavetableLength)
gReadPointers[i] -= gWavetableLength;
// Write the sample to every audio output channel
I think I am missing something from Course 4 online on Youtube.com.
Seth
P.S. If you see where I am making errors, please let me know. Oh...
Bela stopped
redefinition of 'amplitude' column: 8, line: 54
use of undeclared identifier 'amplitudeDB'; did you mean 'amplitude'? column: 31, line: 54
use of undeclared identifier 'centreFrequency' column: 19, line: 57
use of undeclared identifier 'centreFrequency' column: 19, line: 58
