dtl install the included drivers but the installation failed
those are only needed for Windows XP or for older version of the image, I must remember to remove them for the next release.
ok so you are on Windows. Does the board show up as a network device when it's plugged in for more than 30 seconds? If you go to the network settings, you should see an extra ethernet device (that being the ethernet-over-USB to Bela).
