can you try to run this code instead?
If it works, then by comparing it with yours you can probably spot what went wrong 🙂
std::string gFilename = "slow-drum-loop.wav"; // Name of the sound file (in project folder)
std::vector<std::vector<float >> gSampleBuffer; // Buffer that holds the sound file
int gReadPointer = 0; // Position of the last frame we played
// Load the sample from storage into a buffer
gSampleBuffer = AudioFileUtilities::load(gFilename);
// Check if the load succeeded
if(gSampleBuffer.size() == 0) {
rt_printf("Error loading audio file '%s'\n", gFilename.c_str());
return false;
// Make sure we have at least as many sound file channels as audio
// output channels, so we don't crash in render(). This check could
// alternatively be done in render() itself.
if(gSampleBuffer.size() < context->audioOutChannels) {
rt_printf("Audio file '%s' has %d channels, but needs at least %d.\n",
gFilename.c_str(), gSampleBuffer.size(), context->audioOutChannels);
return false;
rt_printf("Loaded the audio file '%s' with %d frames (%.1f seconds) and %d channels\n",
gFilename.c_str(), gSampleBuffer[0].size(),
gSampleBuffer[0].size() / context->audioSampleRate,
gSampleBuffer.size());
// Increment and wrap the read pointer
gReadPointer++;
if(gReadPointer >= gSampleBuffer[0].size())
gReadPointer = 0;
// Write the sample to every audio output channel
float out = gSampleBuffer[channel][gReadPointer];
