I got my sensors today. First impressions good 🙂
I want to use a Craft to make a sensor very like a Bar, but flexible enough to be built into a sleeve or a pad on the forearm. I plan to do this by using a number of lines of a flexible conductor, oversewed to make electrodes that don't touch.
Before In start building, I've got some questions :
Is the width of the electrode important ? Would I be best using a flat braid or would a wire be sufficient ?
There is plenty of residual capacitance as all electrodes have the skin of the arm behind them. I assume Trill does some sort of calibration - will that be sufficient to ignore this ? Or should I try to space the electrodes away from the supporting arm, or place a reference plane between arm and electrodes ?
