Hi all!
I am quite new with Bela. Thank you for this great project!
I've been playing around and I was perkely asking via twitter about if a normal USB keyboard could be used within the Bela environment:
TL;DR: Yes. However, Bela seems to hang up and I cannot properly terminate execution and need to reboot.
On my last tweet I was pointed to an API description about Bela_stopRequested(), see http://docs.bela.io/group__control.html#ga629e9b558394cb0268274b67a1caa752.
I thought this function was delcared in Bela.h which is already included in my program but I get the following compiler error:
/root/Bela/projects/scope-kbd/render.cpp:121:9: error: use of undeclared identifier 'Bela_stopRequested'
while( Bela_stopRequested() != 0 )
Please find the code here:
____ _____ _ _
| __ )| ____| | / \
| _ \| _| | | / _ \
| |_) | |___| |___ / ___ \
|____/|_____|_____/_/ \_\
http://bela.io
A project of the Augmented Instruments Laboratory within the
Centre for Digital Music at Queen Mary University of London.
http://www.eecs.qmul.ac.uk/~andrewm
(c) 2016 Augmented Instruments Laboratory: Andrew McPherson,
Astrid Bin, Liam Donovan, Christian Heinrichs, Robert Jack,
Giulio Moro, Laurel Pardue, Victor Zappi. All rights reserved.
The Bela software is distributed under the GNU Lesser General Public License
(LGPL 3.0), available here: https://www.gnu.org/licenses/lgpl-3.0.txt
#include <cmath>
#include <fcntl.h>
#include <linux/input.h>
// set the frequency of the oscillators
float gFrequency = 110.0;
float gPhase;
float gInverseSampleRate;
int gKeyboardFd = -1;
// global variables to receive keys from the auxiliary thread
bool newKeyEvent = false;
int keyValue = 0;
int keyType = 0;
// instantiate the scope
Scope scope;
// Task for read the qwerty kbd
AuxiliaryTask gInputTask;
void read_kbd(void*);
// tell the scope how many channels and the sample rate
scope.setup(2, context->audioSampleRate);
gPhase = 0;
gInverseSampleRate = 1.0f/context->audioSampleRate;
// start qwerty kbd capture thread
if((gInputTask = Bela_createAuxiliaryTask(&read_kbd, 50, "bela-read-input")) == 0)
return false;
static float out2 = 0;
// iterate over the audio frames and create three oscillators, seperated in phase by PI/2
for (unsigned int n = 0; n < context->audioFrames; ++n)
float out = 0.8f * sinf(gPhase);
gPhase += 2.0f * (float)M_PI * gFrequency * gInverseSampleRate;
if(gPhase > M_PI)
gPhase -= 2.0f * (float)M_PI;
// log the three oscillators to the scope
scope.log(out, out2);
if(newKeyEvent)
if(keyType == 0)
out2 = 0.0f;
else if(keyType == 1)
out2 = 0.8f;
Bela_scheduleAuxiliaryTask(gInputTask);
if(gKeyboardFd)
close(gKeyboardFd);
// Variables keyboard control
struct input_event ev;
ssize_t n;
const char *dev = "/dev/input/event1";
// qwerty keyboard capture
gKeyboardFd = open(dev, O_RDONLY);
if (gKeyboardFd == -1) {
fprintf(stderr, "Cannot open %s:.\n", dev);
return;
n = read(gKeyboardFd, &ev, sizeof ev);
if (sizeof ev == n)
if (ev.type == EV_KEY && ev.value == 0)
keyType = 0; // key released
keyValue = (int)ev.code;
newKeyEvent = true;
else if (ev.type == EV_KEY && ev.value == 1)
keyType = 1; // key pressed
newKeyEvent = true;
return;
Sorry about the mixing of tabs ans spaces, this was not intended.
Best regards!
