Hi, I have a problem with connection. Suddenly bela stopped to communicate with pc through usb. Also blue leds stopped blinking. Only charging does work and the one indicating led blink. Do you have some advice where is problem?thnks.
Connecting bela with pc
gulesz Only charging does work and the one indicating led blink
What do you mean "charging does work"? Is there a blinking LED? Could you explain a bit better what the behaviour of the LEDs is? Is this a Bela or BelaMini? What was connected to the board when this happened?
Blue LED beside the 5V input is lighting. Before, I had connected some buttons, LEDs and knob to analog and digital inputs. I am attaching the short video and I hope it is more illustrating. https://drive.google.com/open?id=1L2updV8fosNAgh1qE_CPInGdPXz1pPrf
Right, it would seem like a corrupted eMMC, almost exactly as in this case here. Do you have an SD card at hand that you could flash? Also, did you try to boot it without the Bela cape?
Thank you very much! It is solved without more complications.
