Hi, I've looked around the forum but I haven't found a solution to my issue and doubts.
I built a simple 4x4 matrix mixer with puredata and I would like control the virtual 16 pots via touchOSC. I started using the "OSCX" PD library then moved to "mrpeach" library. to be sure about the compatibilty with Beagleboard hw, I compiled both library from source on it.
that's what I done, everything works fine, no errors until I move a pot on touchOSC (iPhone)... at this point I receive these messages that will continue to fill the screen even if I stop to touch the pots:
"microsleep select: Bad file descriptor"
"error: udpreceive_read: Bad file descriptor (9)"
Any idea?
thanks in advance
