miguelnegrao Hi How does one turn off the bela board in pepper or salt when installed on the rack ? I imagine that just turning off the general case power could cause filesystem corruption. Thanks, Miguel Negrão
giuliomoro That should be fine. It's recommended that you don't do that only if you have just edited the files. In that case, you'll be already logged into the IDE, so all you need to do is use the graceful shutdown button in the IDE.
