Hi All,
New to the Linux world and probably not as well versed in programming as many - hoping for some pointers to speed along a current project.
The Bela works as advertised - better than anticipated. The examples in the cpp code to get the sound coming in and out of the analog outputs worked with no problems and modifying the samples to get the needed results was not an issue.
The next phase of the project requires the following:
44.1 khz digital audio out in realtime (close as possible) going into a Raspberry Pi 4 where it can there be further edited (potentially with PureData) and also joined with video (from a separate Pi) then uploaded for livestreaming.
After a good amount of digging I have been unable to determine the best method for digital communication between the RPI and BELA and I don't know if it's because it's something simple that I should already know or a tricky problem but should I be looking into:
I2S
USB (serial)
UDP (ethernet)
UART
OSC
16 pins of digital GPIO
Any and all suggestions will be appreciated to help reduce the amount of time needed in research🙂
Thanks,
Zeke Norris
