Hello everyone, '
I've been implementing on my project a Bela trill craft sensor. I was already using Sc language knowing the problems of CPU usage
Integrating it into my patch I can't even use two synths together without having troubles.
In the beginning: I usually reach CPU: 45.2% MSW: 2 (just by applying )
If I add just one synth it goes to 60%. Around 75% the bela crushes.
Is there any solution for this problem? My code you can find attached
there is no attachment. Maybe you posted it in the wrong place here? Either way, better post the code as text.
