the sample-streamer-multi example is doing exactly this. The mixing happens at these lines (note the +=):
float out = 0;
for(int i=0;i<NUM_STREAMS;i++) {
// get samples for each channel from each sampleStream object
out += sampleStream[i]->getSample(channel);
// you may need to attenuate the output depending on the amount of streams playing back
If this is not sufficient for your application, would you mind sharing more details, including your previous experience?
