Hey guys!
Hope you can help me out with the problem that I encounter when connecting to the IDE.
I've downloaded and flashed the new image in which the IDE should be included, and ran through all of the
SSH connect-troubleshooting on https://github.com/BelaPlatform/Bela/wiki/Getting-started-with-Bela#test-the-ssh-connection, tried
$ ssh root@192.168.7.2 and then the message I get from Terminal is: ssh: connect to host 192.168.7.2 port 22: Operation timed out
It isn't able to establish a connection. I'm using MacOSX version 10.14.6 with the 0.3.7b image.
What could be the problem here? I also changed USB cables, used the ones that came with the bela's I purchased.
Thanks a lot,
Cheers, Dianne
