I can't understand why but the example "synchronous-gpio" isn't working at all : the pin won't go up nor blink.
I tested :
-the Led and resistor with the example digital output, it works very well
-the "Use Digital" Label is off (I also tested with "on" )
-tested with multiple GPIOs numbers some which were part of the I/O of Bela and some which weren't.
-with multimeter, I ensure that the pin is not floating it stays down.
-I have no error in console... (except when I selected wrong GPIO numbers which was normal)
-Update Bela firmware + IDE
Does anyone have an idea of what I could try ?
Sadly, I can't go with the digitalWrite instead of Gpio.h because I need to deal with those Gpio outside of render in an auxiliary process... (I want to run a Menu with light graphical interface but I want the audio to be priority).
