Hi guys... I am currently working on an audio device that requires 17 pots, 15 leds and 45 buttons.... So if I am correct, this is 60 digital inputs and 17 analog inputs....
What are my options to get this to work on Bela ?
Thanks.
Thanks.
The Bela multiplexer capelet expands the analog inputs to 64 (with reduced sampling rate). You could use that for the 17 pots and 45 buttons. Then use 15 digital I/Os for the LEDs.
giuliomoro Oh so I was wrong .... buttons (regular keyboard mechanical switches) require analog inputs ?
dadasane buttons (regular keyboard mechanical switches) require analog inputs
no, you would normally use digital inputs. However, you can use them with analog inputs, and just threshold them in the software.
giuliomoro Ok thanks Boss ! I'm ordering the Mux this coming weekend
giuliomoro I just realised that I didnt really understand what you meant by "thresholding the analog inputs in the software" in order to use them as digital ones for my switches....
what I mean is that you start by connecting the switch as usual:
3.3V
Z R1 10k
Z
+----------------To Analog or digital Input
/ switch
Gnd
then if you connect it to the digital input, you will get only readings of 1 when it's not pressed and 0 when it's pressed. If instead you connect it to an analog input, you will read values around 0.8 when it's open and around 0 when it's closed. What I mean by thresholding is that you'd consider the reading a "digital 1" if it's above 0.5 and a "digital 0" if it's below 0.5. Something like:
analogValue = multiplexerAnalogRead(context, input, muxChannel);
digitalValue = analogValue > 0.5.
See, here and here for more info on the multiplexerAnalogRead()
function
Does it make more sense now?
giuliomoro yessssssssssssssssssssss !!!!!!!!!!!!!!!!!!!!! thankssssssssssssssss !!!!!
Hi, as far as I'm concerned, there's currently no way to expand the number of analog inputs on Bela Mini - am I right, or am I (hopefully) missing something? Currently I'm using an external microcontroler (Teensy 3.2) connected to Bela Mini as a midi controller in order to get those extra analog inputs that I need, but it's rather clumsy and otherwise not ideal...
How many extra inputs do you need? There are 8 more available on BelaMini, though one is one the same pin as one LED (so it has limited range) and one is on the same pin as a digital I/O (so only one of the two functions can be enabled). Most of these have a strict 0V:1.8V range, and they are all slower to read than the Bela analogs, but it seems that they can work nicely in your case. If you only need 7 or 8 extra channels, these may work, but if you need more, you could look at building a little breakout board with a multiplexer on board which works similarly to the Multiplexer cape for the bigger Bela.
giuliomoro !!!OH that would be great!!! I only need 3 or 4 additional analog ins, so that sounds perfect! Could you specify how to access these inputs and whether they're available from Pure Data?
to access those one needs to read the files /sys/bus/iio/devices/iio:device0/in_voltage0_raw
, /sys/bus/iio/devices/iio:device0/in_voltage1_raw
etc , where the number corresponds to the ADC number in this pinout. Not sure this can be done straight from Pd without causing mode switches and dropouts, so one may have to write a bit of C++ code to wrap those. What would you use in Pd to read a file on disk? We can give that a try first.
Does the file "...in_voltage0_raw" have some extension? Just making sure I'm getting it right - the file gets automatically updated every now and then and holds a latest value of a given pin?
Regarding reading files in PD I've tried something among these lines:
with the [textfile] object, but it's unfortunately for text files exclusively. There's gotta be some other way, I'll look into it.
krzysztofcybulski Does the file "...in_voltage0_raw" have some extension? Just making sure I'm getting it right - the file gets automatically updated every now and then and holds a latest value of a given pin?
that's correct. It's a virtual text file (without a newline at the end). The value you read is a string containing values between 0 nad 4095. Every time you read it, it goes and takes a measurement of the ADC and returns that value. So it's not real-time safe at all. As it's a virtual file, it seems that Pd is having trouble to read it. We'll have to make a C++ workaround I guess.
OK I have something working: drop this render.cpp
file in your Pd project and use something like this with [unpack]
or similar:
[r bela_lowResAnalogIn]
[print]
It reads every 50 ms more or less, not sure how much faster than that it can go.
As mentioned before, use the pinout here and triple check that you do not send more than 1.8V to each of the 1.8V inputs. You can use P1.18 "REF+ AIN 1.8V" as a 1.8V voltage reference to drive your potentiometers/sensors. I am not 100% sure whether this is properly buffered. Wire up a few pots/sensors and see if you are getting any crosstalk between them, as that would be an indication that you need a buffer on that voltage reference.
!!! Thanks a lot!!! I'll give it a try!
giuliomoro You must forgive me, but I'm totally dub when it comes to Linux, command line etc.
By "drop this file" you mean dropping it by using the Bela IDE? I've done it and the file is visible, yet, when I try to run the project on Bela, I get the following:
Makefile:483: recipe for target '/root/Bela/projects/test_czytania_pliku_analog_in_dodatkowe/build/render.o' failed
and:
'libraries/libpd/libpd.h' file not found column: 10, line: 33
Not sure how to deal with it.
Apologies again, cuz it's probably bread and butter for anyone familiar with Linux coding...
just update your Bela core code and try again. Instructions here: https://learn.bela.io/using-bela/bela-techniques/updating-bela/
giuliomoro Works great now, thank you! Your advice and commitment is priceless, as always!
