I've git cloned the latest Bela and got the Web IDE working, ran a few examples etc.
But I want to write code using VS Code and compile/run via the sh scripts.
So I navigate to the scripts folder and run the following
./build_project.sh ../examples/Fundamentals/sinetone
I then get the following
Checking the board is up and running at root@192.168.7.2...ssh: connect to host 192.168.7.2 port 22: Operation timed out
ERROR: the board does not respond at root@192.168.7.2, check that the address is correct and the board is connected.
Checking the board is up and running at root@192.168.6.2...Warning: Permanently added '192.168.6.2' (ECDSA) to the list of known hosts.
done
Board found at root@192.168.6.2
Stop running process...
Copying new source files to the board...using rsync...
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: error in rsync protocol data stream (code 12) at /BuildRoot/Library/Caches/com.apple.xbs/Sources/rsync/rsync-54/rsync/io.c(453) [sender=2.6.9]
Error while copying files
As I'm a novice with Bela anyone help me with this.
I'm using VS Code as I've been using it for 3 years writing JavaScript / React.js btw
Is there some permissions violation with mac Catalina ?
Or is the differing IP .7.2 .... .6.2 got something to do with it ?
