JamesStick Hi, I'm new with Bela. I'm trying to get started with Bela but I have some problems on mounting the Bela image on the SD card. I'm on MacOS 10.14.6. First of all I download the file bela_image_v0.3.6b.xz and I uncompress it, but the bela_image_v0.3.6b is not recognised and I can't open it. So I followed the instructions from this page https://github.com/BelaPlatform/Bela/wiki/Manage-your-SD-card#flashing-the-bela-image. But when I arrive to the step "Writing the image to the SD card" the command "$ sudo dd if=/path/to/inputFile.img of=/dev/mydisk bs=1024k" doesn't work. I change the path and the file name, but the message is always "no such file or directory". How can I solve this problem? Thank you.
giuliomoro It looks like the path /HD/Utenti... is wrong. Can you check that it is correct? You can also cd to the folder containing the .img file and use the relative path (e.g.:if=bela_image_v0.3.6b.img )
